Security Issue AC87
Sky
I caught this bit of data in my log. The ip's trace to known bad actors, but this is a new twist tapping high ports, etc. I've seen the bot scans for PPTP b ut this is different than normal, perhaps OpenVPN scans? I don't know, can someone take a look at this? I can send the log in full if needed.
Oct 29 07:59:49 vpnserver1[1095]: 192.241.201.221:34728 TLS: Initial packet from [AF_INET]192.241.201.221:34728 (via [AF_INET]98.36.240.130%eth0), sid=01000000 00000000
Oct 29 07:59:49 vpnserver1[1095]: 192.241.201.221:34728 TLS Error: reading acknowledgement record from packet
Oct 29 08:00:49 vpnserver1[1095]: 192.241.201.221:34728 [UNDEF] Inactivity timeout (--ping-restart), restarting
Oct 29 08:00:49 vpnserver1[1095]: 192.241.201.221:34728 SIGUSR1[soft,ping-restart] received, client-instance restarting
Oct 29 13:43:28 vpnserver1[1095]: 185.200.118.71:45378 TLS: Initial packet from [AF_INET]185.200.118.71:45378 (via [AF_INET]98.36.240.130%eth0), sid=12121212 12121212
Oct 29 13:44:28 vpnserver1[1095]: 185.200.118.71:45378 [UNDEF] Inactivity timeout (--ping-restart), restarting
Oct 29 13:44:28 vpnserver1[1095]: 185.200.118.71:45378 SIGUSR1[soft,ping-restart] received, client-instance restarting
Oct 29 14:39:48 vpnserver1[1095]: 167.94.138.22:30734 TLS: Initial packet from [AF_INET]167.94.138.22:30734 (via [AF_INET]98.36.240.130%eth0), sid=4d658221 07fcfd52
Oct 29 14:40:03 vpnserver1[1095]: 167.94.138.60:46245 TLS: Initial packet from [AF_INET]167.94.138.60:46245 (via [AF_INET]98.36.240.130%eth0), sid=f87caac7 6749fcd0
Oct 29 14:40:48 vpnserver1[1095]: 167.94.138.22:30734 [UNDEF] Inactivity timeout (--ping-restart), restarting
Oct 29 14:40:48 vpnserver1[1095]: 167.94.138.22:30734 SIGUSR1[soft,ping-restart] received, client-instance restarting
Oct 29 14:41:03 vpnserver1[1095]: 167.94.138.60:46245 [UNDEF] Inactivity timeout (--ping-restart), restarting
Oct 29 14:41:03 vpnserver1[1095]: 167.94.138.60:46245 SIGUSR1[soft,ping-restart] received, client-instance restarting
Thanks,
Sky
Looks like normal port scanners to me (although as you say they don't normally bother with high ports).
Interestingly the 167.94.x.y addresses are from censys.io. I noticed that since only a couple of days ago they've been aggressively scanning all ports on my router, even the high ports. That's new. I've now blocked them.
Sorry to be so late — forgot to say "Thanks!"
