FreshJR
I know this question isn't really 100% Merlin-WRT related but I will be using the eval command within my QoS script in an attempt to pass parameters "ByReference" to a function. The answers I get will affect Merlin-WRT in a round-about way.
I already looked this up on stack-exchange exchange and got both answers that eval is the devil and also a proposed solution that should be safe.
I am not 100% sure if it is safe so I would like to ask here first.
Here is a simple easy to read shell example.
The code works as expected. Just worried about security.
I tried privilege escalation by escaping the quotes via the following input
and it didn't escalate like I thought it would.
Is the stackexchange answer safe?
(I do have a messy alternative to eval via 48 almost duplicate functions instead a few byreference equivalents.)
byref()
echo -n "$1=" && eval "echo \${$1}"
input="bar" # this can be any user input
eval "$1=\$input"
var="foo"
byref var
echo "var=${var}"
########OUTPUT########
var=foo
var=bar
not worried about first eval since $1 is explicitly/controlled passed from the "main" function
am worried about second eval due potential to arbitrary command execution user input to escaping quotes
input='bar" && eval "echo here'
