See all Devices on Network?
Debu
Network Map -> View List (Where the computer is) used to show all the devices on the network.
I used to be able to see my other switches and things like that in the official firmware.
In Merlin, I only see the active device. I'm not sure I'm using the right terminology.
Anyway, is there a way to see every device on my network again?
I'm looking at restructuring IP address.
Thanks.
No router model given. No firmware version given. :rolleyes:
Known issue, search the forums and look in the changelog of the firmware.
  - KNOWN ISSUE: Networkmap listing may be unreliable.
                 (Bug in Asus's code)
  - KNOWN ISSUE: Users failing to read changelogs will
                 probably complain about the above issues.
                 (Outside of my control).
Hi Colin,
Thank you for letting me know. I guess I have to wait for a fix from ASUS.
You Rock!
Hi Colin,
You Rock!
You can let us know your router model and current firmware version as this is fixed for most routers already.
Don't worry, what you share on snb, stays at snb. :) :D
It is a RT-AC5300 with 384.10_2 Firmware.
384.11 Beta 2 has already incorporated the fix from the Asus latest '713 GPL. :)
It's still not working if it's suppose to. Right now, I can't my see my TV in the client list and it's a wired device. The only time any devices show is when they are actually doing something over the network. My PC is the only thing that's always there. RT AC-68U with 384.11_beta2 firmware. I just don't worry about anymore.
It is working for many just doing a 'dirty update', but if not for your specific case then a full (M&M Config) reset is probably needed. Particularly if you haven't performed one recently.
yes a few devices still not seen eg NEST smoke detector - 95% seen -and I am not BSUYA
