Select which client connects to which VPN if any.
xiaokai
I was wondering if there was a way to get certain clients to send its traffic through certain VPN profiles, and set some clients not to go through VPN.
for example, I have set up the VPN in the router, and all traffic goes through it.
However there are times where some clients will not work, for example Amazon Fire TV will not work through PIA UK Server.
So is there a way to set the Amazon Fire TV client to not connect via VPN but allow laptops to connect.
Have you looked at the README included with the firmware? All documented there.
There is a way.
Check the vpn sub forum.
Should be right at the top as i have posted a question.
I want to do the same but on stock firmware as i dont want to upgrade to merlin yet.
Trying to get my PS4 isolated to the vpn client i have without having to keep disconnecting others
