Loader:raw Filesys:tftp Dev:eth0 File:: Options:(null)
Loading: TFTP Server.
..tftp retry wait 0
Failed.
Could not load :: Timeout occured
Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: .... 4076256 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
brd: module loaded
loop: module loaded
pflash: found no supported devices
bcmsflash: found no supported devices
Boot partition size = 524288(0x80000)
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 28
Creating 4 MTD partitions on "nflash":
0x000000000000-0x000000080000 : "boot"
0x000000080000-0x000000200000 : "nvram"
0x000000200000-0x000004000000 : "linux"
0x00000039fc40-0x000004000000 : "rootfs"
PPP generic driver version 2.4.2
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPTP driver version 0.8.5
Mirror/redirect action on
u32 classifier
Performance counters on
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (3991 buckets, 15964 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
Registering the dns_resolver key type
Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2 012
NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
Spare area=64 eccbytes 56, ecc bytes located at:
2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Available 7 bytes at (off,len):
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Scanning device for bad blocks
Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Creating 2 MTD partitions on "brcmnand":
0x000004000000-0x000007ec0000 : "brcmnand"
0x000007ec0000-0x000008000000 : "asus"
VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
devtmpfs: mounted
Freeing init memory: 212K
Digital core power voltage set to 1.0V
Decompressing...done
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001BB
000011F0
RDLYW0 00000004
RDENW0 00000030
RDQSW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ----+++++++++++++++++++++++X+++++++++++++++++++++++-------------
01 -----++++++++++++++++++++++++X++++++++++++++++++++++++----------
02 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
03 ------++++++++++++++++++++++X++++++++++++++++++++++-------------
04 ---++++++++++++++++++++++X++++++++++++++++++++++----------------
05 --++++++++++++++++++++++++X+++++++++++++++++++++++--------------
06 ----+++++++++++++++++++++++X+++++++++++++++++++++++-------------
07 ----++++++++++++++++++++++X+++++++++++++++++++++----------------
08 ----+++++++++++++++++++++++X+++++++++++++++++++++++-------------
09 -----++++++++++++++++++++++X++++++++++++++++++++++--------------
10 -----++++++++++++++++++++++++X+++++++++++++++++++++++-----------
11 ---+++++++++++++++++++++++X+++++++++++++++++++++++--------------
12 --++++++++++++++++++++++X++++++++++++++++++++++-----------------
13 --++++++++++++++++++++++++X+++++++++++++++++++++++--------------
14 --++++++++++++++++++++++++X+++++++++++++++++++++++--------------
15 -+++++++++++++++++++++++X++++++++++++++++++++++-----------------
PW0
00 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------
01 -+++++++++++++++++++++++++++X++++++++++++++++++++++++++---------
02 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
03 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------
04 ++++++++++++++++++++++++X+++++++++++++++++++++++----------------
05 -+++++++++++++++++++++++++X++++++++++++++++++++++++-------------
06 -+++++++++++++++++++++++++X++++++++++++++++++++++++-------------
07 ++++++++++++++++++++++++X+++++++++++++++++++++++----------------
08 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------------
09 -++++++++++++++++++++++++X++++++++++++++++++++++++--------------
10 --++++++++++++++++++++++++++X+++++++++++++++++++++++++----------
11 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------------
12 ++++++++++++++++++++++++X+++++++++++++++++++++++----------------
13 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
14 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
15 +++++++++++++++++++++++X+++++++++++++++++++++++-----------------
NW0
00 -----+++++++++++++++++++++++X++++++++++++++++++++++-------------
04 ----++++++++++++++++++++++X++++++++++++++++++++++---------------
07 ----+++++++++++++++++++++++X++++++++++++++++++++++--------------
08 ----++++++++++++++++++++++++X+++++++++++++++++++++++------------
09 -----+++++++++++++++++++++++X++++++++++++++++++++++-------------
11 ---++++++++++++++++++++++++X+++++++++++++++++++++++-------------
14 ---+++++++++++++++++++++++X+++++++++++++++++++++++--------------
WRDQW0
00 ++++++++++++++++++++X++++++++++++++++++++----------++++++++++++-
01 ++++++++++++++++++++++X++++++++++++++++++++++-----+++++++++++++-
02 ++++++++++++++++++++++X++++++++++++++++++++++------++++++++++++-
03 +++++++++++++++++++++X++++++++++++++++++++--------+++++++++++++-
04 +++++++++++++++++++X+++++++++++++++++++-----------+++++++++++++-
05 +++++++++++++++++++++X++++++++++++++++++++--------+++++++++++++-
06 ++++++++++++++++++++X++++++++++++++++++++---------+++++++++++++-
07 +++++++++++++++++++++X++++++++++++++++++++----------+++++++++++-
08 +++++++++++++++++++X+++++++++++++++++++-------------+++++++++++-
09 +++++++++++++++++++++X++++++++++++++++++++---------++++++++++++-
10 ++++++++++++++++++++X+++++++++++++++++++----------+++++++++++++-
11 ++++++++++++++++++++X++++++++++++++++++++----------++++++++++++-
12 +++++++++++++++++++X+++++++++++++++++++-----------+++++++++++++-
13 +++++++++++++++++++X+++++++++++++++++++-+----------++++++++++++-
14 +++++++++++++++++++X+++++++++++++++++++------------++++++++++++-
15 ++++++++++++++++++X+++++++++++++++++---------------++++++++++++-
WRDMW0 00000020
WRDMW0 00000019
ADDR
00 +++++++++++++++++S+++++++++++++X++++++++++++++++++++++++++++++++
Detect CPU turbo button...
CFE version 6.37.14.86 (r456083) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
Build Date: 二 4月 22 16:05:16 CST 2014 ([email protected])
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.86 (r456083)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
CFE mem: 0x00F00000 - 0x01795558 (9000280)
Data: 0x00F4DBB4 - 0x00F4E080 (1228)
BSS: 0x00F4E090 - 0x00F93558 (283848)
Heap: 0x00F93558 - 0x01793558 (8388608)
Stack: 0x01793558 - 0x01795558 (8192)
Text: 0x00F00000 - 0x00F4430C (279308)
Device eth0: hwaddr , ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Null Rescue Flag.
boot the image...
