Hi
Im going to be setting up a guest network on my AC86U, although It will not be used that often I would prefer to keep it enabled 24/7 as I don't want to have to keep enabling as and when.
Also keep it to 2.4ghz band only and restrict access to my local network.
I have something I'm unsure of, should the guest 2.4ghz band use the same channel as my own 2.4ghz band or should it be different ?
Any other settings advice much appreciated.
