Setting up an Access Point using two routers
Hi everyone,
I have a netgear router set up and was given a tp link archer 7 router. I have the netgear setup for my home wifi and want to use the tplink as an AP. Is that possible??? Also, may I ask for some help trying to set that up!
Thanks!
Yes it can be done - check the main site on how to convert a Router/AP in to a dedicated AP...
Read this
or just
C7 running AP
Disable Firewall
Disable DHCP on LAN
Disable NAT
Internet cable goes to LAN1 (or any LAN port) on C7 - and to the main router (Any) LAN port.
Set C7 IP to a fixed IP 192.168.X.X
Restart both routers
Done!
