Setting up node with 86U question.
Morganza
This is my first but not likely my last question. If I add another 86U device as a node, do I use the same settings as on the 86U router? Channel number, and all other settings, etc?
Thanks,
Morgan
if you set it as a node all your settings from your main router will be copied automatically to your node. all you have to to is just add it.
Thanks,
Morgan
Some AiMesh install notes.
OE
