1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Setting up two Asus routers to extend wifi
Discussion in 'Asuswrt-Merlin' started by Briant73, Jun 30, 2020 at 7:21 PM.
  1. Briant73
    Briant73 Regular Contributor
    Oct 3, 2008
    90
    I have both an 86u which i'm currently running as my only router, it works well but I'd like to extend my wireless range, which I have an older 68u sitting on a shelf in case I need a backup router. I have updated both to rmerlin 384.18 but have more than a few questions, I did some searches that seemed to result when Mesh was new and buggy or not even available on rmerlins fw.
    1) I am going to use Ethernet between the two routers, should I go with setting up Mesh mode or do I go with setting up the 68u as an AP?
    1a) Is there a good guide for mesh and ap setup?
    2) The Ethernet back haul currently comes from the 86u to a small gigbabit switch that serves 6 wired devices currently, should I plug the 68u into that switch or the Ethernet into the 68u directly and then the switch into the 68u or it doesn't matter?
    3) Should I use same SSIDs or different for devices?
    3a) What about channels?
    4) Any major gotcha settings to be aware of?
    Thanks!
  2. Rooter
    Rooter New Around Here
    May 9, 2013
    6
    It may not still be an issue, but the last time I tried a similar setup it appeared that guest Wi-Fi access restrictions differed between the primary router/AP versus that of the secondary router/AP. If I recall correctly, I configured the secondary device as just an access point as I did not have any sort of mesh mode available at the time. I did try alternate configurations with the secondary device also configured as a router, but I recall complications with IPv6 DHCP assignments, possibly being limited to or available only to devices connected to the primary router.
  3. QuikSilver
    QuikSilver Very Senior Member
    Jan 30, 2019
    675
    BFE
    1)I'd use a ethernet cable if you can. Wired over wireless would be more reliable.
    2)If you can take out the switch and go directly to the router. The less items you have in your network, the easier to track down where the issue may be.
    3)I use the same ssid across 2.4 and 5ghz using the smart connect feature. Your mileage may vary as some recommend to turn that off.
    4)None I can think of right now. ;)
  4. Briant73
    Oct 3, 2008
    90
    Thanks, I edited my first post but here are my answers -
    1) I meant to say i will be using ethernet.
    2) I have to many wired devices at the same area, I can't remove the switch and have more devices than the 68u can handle, so just wondering if I should do devices to switch to 68u or devices and 68u to switch.
    3) I am attempting same ssid, what about channels? Do I use smart connect on just the router or both the router and ap?
  5. QuikSilver
    Jan 30, 2019
    675
    BFE
    2) Not exactly sure what you're asking here. "wondering if I should do devices to switch to 68u or devices and 68u to switch"
    3)Spacing the channels out on the 2.4ghz band is best practice. Use either 1, 6, or 11, Whatever you use on switch use next for AP.
  6. JT Strickland
    JT Strickland Senior Member
    Sep 19, 2019
    222
    1) I have a similar setup with ethernet backhaul, and debated about the ap and the mesh method also, and wound up going with the mesh. I am no expert, but they both have advantages. I do like the automatic switching from the node to primary router when I walk from my home to small office without any apparent change on my iphone, or without switching networks.
    2) I have my ethernet from my primary router to a switch, which branches to the node, a tablo, a two bay nas, and other clients. My thinking was to take any work out of the router that could be handled efficiently elsewhere, but that may not be valid logic. It has worked well so far.
    3)I have separate ssid's for the 2.4 and 5 ghz bands so I can choose which I want with clients.
    FWIW I set my control channels based on other traffic and smart connect is turned off I believe.
    QuikSilver likes this.
  7. zackattack784
    zackattack784 Occasional Visitor
    Dec 19, 2019
    29
    I too went back and forth between mesh and AP (wired). I went the AP route. I used same SSID, smart connect, and DIFFERENT channels for the router and AP. Works great for me.
  8. Briant73
    Oct 3, 2008
    90
    Wanted to update - I tried ap mode with my 86u as router and 68u as an ap, wifi signals were great all over my house and outside on my deck but I think I had some major issues with interference or something, seemed like devices would lag where before they didn't. Possibly my routers are too close in the house but I turned off the AP and all of the sudden my devices no longer seem to lag like they were before.
    My setup was separate ssid for 2.4g and 5g, different control channels for the ap and router, and smart connect off. Any ideas what to check?
    Also can someone send me the rmerlin default wireless professional settings for an 86u for 2.4 and 5g? I wanted to compare those to mine.
