Settings don't apply
OBENZ
Just got my ac86u and I'm already frustrated by its GUI. A
Updated to latest version buy everytime.i change something and click on Apply nothing happens. I want to disable dhcp on it so I can keep bought my ISP modem and this one on same subnet/network. It doesnt work. I want to enable WDS so that my older router can bridge wirelessly with this one but doesnt work. I enabled qos but it doesnt work...I keep rebooting but nothing
Try a different browser, and also disable any browser addons that might potentially interfere.
Well what do you know there was an ad blocker messing up the whole thing:(
Updated to your firmware. Now I do have a question, if you can enlighten me.
I have a ISP router/modem in my kitchen, now I need to see all my devices across the network, if I plug the router/modem into the wan of the router it creates a new network/subnet but I'd like to have same network so that all my devices can communicate. Should I use the LAN port of the router instead of the WAN?or use the router as AP?
Set the router to AP mode, and still use the WAN port for the uplink to the primary router.
That's what I did at first but then I lost all functions I bought this router for...qos, monitoring etc. I spent the last 12 hours setting this up and I wish I never switched. My last problem is I have 2x10tb ext4 hooked to the Asus but no device can read or even find these 2 :(
Auto refresh
:24 kernel: sd 1:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
May 5 06:05:24 kernel: sd 1:0:0:0: [sdb] 15628052480 512-byte logical blocks: (8.00 TB/7.28 TiB)
May 5 06:05:24 kernel: sd 1:0:0:0: [sdb] 4096-byte physical blocks
May 5 06:05:24 kernel: sd 1:0:0:0: [sdb] Write Protect is off
May 5 06:05:24 kernel: sd 1:0:0:0: [sdb] No Caching mode page found
May 5 06:05:24 kernel: sd 1:0:0:0: [sdb] Assuming drive cache: write through
May 5 06:05:24 kernel: sd 1:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
May 5 06:05:25 kernel: .ready
May 5 06:05:25 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
May 5 06:05:25 kernel: sd 0:0:0:0: [sda] 15628052480 512-byte logical blocks: (8.00 TB/7.28 TiB)
May 5 06:05:25 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
May 5 06:05:25 kernel: sd 0:0:0:0: [sda] Write Protect is off
May 5 06:05:25 kernel: sd 0:0:0:0: [sda] No Caching mode page found
May 5 06:05:25 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
May 5 06:05:26 kernel: sd 1:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
May 5 06:05:26 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
May 5 06:05:26 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
May 5 06:05:26 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
May 5 06:05:27 usb: USB ext4 fs at /dev/sdb1 mounted on /tmp/mnt/easystore.
May 5 06:05:30 rc_service: hotplug 1247:notify_rc rest
You will have to make a choice. Either it as a router and connect everything to it, or use it as an AP, and lose all routing-related features. You can't have both.
It's difficult to suggest anything without seeing the complete log and knowing your configuration settings and what you're trying to do. But the fragment of the log that you posted shows an 8TB drive being successfully mounted.
Yea sorry, so one was ext4 and it mounted the other one was ntfs and the router didnt like it so I hooked another 10tb which is also ext4 and mounted fine.
May 5 08:51:02 smbd[11017]: [2018/05/05 08:51:02.858349, 0] smbd/smb2_read.c:219(smb2_sendfile_send_data)
May 5 08:51:02 smbd[11017]: smb2_sendfile_send_data: sendfile failed for file Detroit.2017.2160p.BluRay.HEVC/BDMV/STREAM/00002.m2ts (Broken pipe). Terminating
May 5 08:51:20 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
May 5 08:51:24 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
May 5 08:51:31 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
What's happening ?
What's happening ?
It would be helpful to know what you were doing at the time so we can put the error messages into context.:rolleyes: Beyond that all we can say it that a file transfer over SMB terminated unexpectedly and a device plugged into port 1 started "flapping".
Yea sorry,
So fixed the broken pipe error, had to disable smbv2. As for the other thing. My ISP router is hooked to my router through powerline via the LAN port not the WAN as I dont want to have 2 networks and that's the port that's causing the problem
