Setup - Enhanced traffic monitoring?
shoe
I have installed Merlin 3.0.0.4.374.35_4 on a N66U, was wondering what the exact setup for it was and how to view the stats.
I remember seeing the instructions but can't seem to find it now? I have formatted a 8GB USB Drive to ext3 and inserted the drive but not sure where to set the save location as I cannot determine the mount point of the drive (selecting it through the GUI sets it as /mnt/) and have set "Create or reset data files".
I am currently deployed in a field environment and we have purchased our own VSAT but have a quota, just would like to keep track of per-ip usage on the users to weed out accidental Cloud syncing or large downloads outside of our quota free period.
Any help would be greatly appreciated.
tools > run cmd
mount
it'll probably be /mnt/sda1
[edit/]
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda1 on /tmp/mnt/sda1 type ext3 (rw,nodev,noatime,data=ordered)
i know it says /tmp/mnt/sda1, but i guess it gets symlinked or something to /mnt/sda1 and is what you should use
This is all I get
looks like it might not be formatted correctly, try
fdisk -l
that's an L
Disk /dev/sda: 8004 MB, 8004304896 bytes
255 heads, 63 sectors/track, 973 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 974 7816703 83 Linux
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(1023, 254, 63) logical=(0, 0, 3)
Partition 1 has different physical/logical endings:
phys=(1023, 254, 63) logical=(973, 34, 21)
think you might want to wipe the partition table and start over. use a gparted live iso and be sure to Write the new partition table before formatting. looks like you tried to format the disk rather than the partition or something
Can't seem to properly format my flash drives... Using a PartedMagic live cd w/ gparted. I can't format into ext2/ext3 but can do ntfs,exfat, and fat32. Would any of those other formats be supported? I only have Windows OS here besides the live cd.
yea, use fat32. for your use, it wont matter much.
just dont use ntfs (it sucks on linux, really) and exfat isn't supported, afaik
USB Application > Servers Center > Misc Setting
give it a device name. i have all the yes/no options set to yes, but that's your preference
Network Place(Samba) Share / Cloud Disk
Enable sharing
you'll be able to see the router in your network neighborhood or whatever from windows and should able to access the usb drive without a password by default, iirc. if not, play with the settings til they are at what you want.
haven't ever used the logs, but i imagine it'll be in a simple text format, view via Notepad, etc.
or just pull the drive and open them up on your computer
Just noticed that I now have a "Per-Device" section under the traffic monitor, the information there is exactly what I've been looking for. Doesn't seem to let me rule out certain times but this will do.
Only thing I wonder about now is if this counts internal network traffic as well as internet traffic?
Setup the Samba server earlier and that's where I saw the two files, the files just turn up as gibberish.
No, only traffic going through LAN is accounted.
Thanks for your help sinshiva and RMerlin.
This feature will help a lot, figured out it was someone who had Dropbox enabled on their iPad that was eating up our quota.
Very nice FW that has been developed, will definitely be donating.
Got a N65U to use as a AP in a different building for the same network and wish I had known Merlin before I bought it. Any reason it is not supported for the N65U?
N65U has a different cpu architecture (as does the N56U which is also not supported by RMerlin).
The N65U is based on a Ralink chipset. I only develop for the Broadcom platform.
Padavan does offer an extensively improved firmware for the RT-N65U, I would recommend taking a look at it.
RMerlin, thanks for the correction.
So does this mean you (possibly) won't be supporting the Quantenna based RT-AC87U?
I know this is far out into the future - but it would sure affect my future buying/recommending decisions.
Until we know more about this router, it's impossible to tell. Latest rumors were that it would still be using a Broadcom CPU, but would use a Quantenna SoC for the radio. If that's true, I have no idea what implications it will have on the architecture, how extensive Asus's changes to Asuswrt will be to accomodate this, etc...
