SFP+ vs RJ45
Wouldn't that depend on what your ISP service is delivered as? Or, do you have a choice?
If you have a choice, and you also have a 10GbE switch (which doesn't have SPF+) to connect the RJ45 Port to, then your choice seems likes it's made for you. :)
I have a 10 gtek and a mikrotik 10gb transceiver. From a switch that I'm trying to set up at my work. Was just wondering if its better to use them then the rj45 port. I have comcast gigabit plan with the new moto mb8611 for my isp. I live in baltimore city and fios isn't available yet.
Not familiar with your equipment or your ISP.
I hope that the parts you have will give you greater than 1Gbps speeds (as your modem allows it).
