JJQuin
I currently have two USB hard drives attached to my RT-AC86U running Merlin 382.2_beta3.
1. 4TB USB hard disk, formatted ntfs, 1 partition, used for SMB & NFS Shares
2. 8GB USB flash drive, formated ext2, 2 partitions (2GB swap, 6GB data), used for entware, AB-Solution, etc.
I would like to hide the 8GB flash drive from the Samba share list. When I connect from my Windows PC or Android Tablet, I see all folders on the 4TB and the 8GB data partition. I have usernames/passwords setup so my family can't access the folders on the 8GB data partition, but I would prefer if I could just hide it completely.
I tried to figure out how to setup a smb.postconf using the pc_delete or pc_replace commans, but I need to remove or comment out 3 sections at the bottom of the file and a lot of the lines in each section are exactly the same. The only way I could figure out how to do it would be to completely replace the smb.conf with one in /jffs/configs, but I'd prefer a way that wouldn't require me to edit the file each time I changed, removed or added folders to the root of the 4TB drive.
Any suggestions?
Any suggestions?
