Hi all,
I currently have a small home network. Devices are as follows:
Wired:
TiVo V6 box (living room)
TiVo V4 box (bedroom)
LightwaveRF hub (G1 - plus 6 G1 devices wifi linked to the lightwaveRF hub)
Apple TV G4
Work Laptop
TV (not smart but linked for updates)
Wifi:
iPhone & iPad (plus guest i/Phones & i/Pads)
MacBook
External backup drive wired to the MacBook (using CCC)
Home Laptop
External backup drive wired to the laptop (using Acronis)
Garmin Index Scale
As you'll probably guess from the TiVo, I use VirginMedia to provide my optical broadband (hub 3 at 250mbs/12mbs) but recently bought an ASUS AC86U (on it's way) after reading so many reviews on so many routers from all sorts of resources, obviously including this one and the main SNB site, and will add that I found this forum (and SNB) so helpful, that after reading a review here & at SNB, then reading another review elsewhere, I would always come back to the SNB site and this forum to get the last word. Fantastic resources! Anyway, back to the challenge.
Currently, I have to swap cables when I want to use a device as the router only has 4 ports and I know that all I need is an unmanaged switch.
The problem comes when I think about the not to distant future where I plan to get a NAS and a game console (hence the AC86U).
I'm guessing I don't really need security unless it's from external connections which I presume the router will take care off to a degree (please correct me if I'm wrong). My thinking is more around controlling the traffic because of the TiVo, NAS and console.
Question 1: Because these three devices, I imagine, are going to be quite busy, should I buy a smart switch or will an unmanaged switch be enough?
Another reason for the doubt is that unmanaged switches here are anything from £10-£40, but so are some smart switch, such as the LGS308, so I'm thinking, if I'm going to spend around £40+- then why not get a smart switch!
Question 2: if it is a smart switch, would you recommend the LGS308 to cover all 8 devices, as well as any possible future expansion?
Question 3: Can a smart switch be used as an unmanaged switch until the time comes when I need something more configurable?
Many thanks in advance for any help that anyone can provide, or suggestions.
Wired:
Apple TV G4
Work Laptop
Wifi:
MacBook
Home Laptop
Garmin Index Scale
