frankhere
Simple question:
What could one do to improve / increase the performance of a router ?
Note this is more academic than an actual need...
The way I look at it is the router is like a fire hose. You turn it on and you have max. throughput to begin with. The only thing you can do is reduce that throughout ( Gal per min = Mbps) by monkeying around with the settings.
Now I know some one will mention " if you change the volume and pressure (* the fire plug or Internet provider speed and the modem) you can improve the performance. Yep I get that. That aside ( and understood as a critical part of the performance chain) , is there other things that should be considered?
This goes under the mind set of optimizing the Router to get the best performance.
Thanks!!
Thanks!!
