simultaneous dual-band (dual radio) router/ap
stangri
I'm looking for a single device which can simultaneously create a 2.4Ghz g-only network for my older devices and a 5Ghz n-only network for the newer ones.
I know Apple makes a router which can do this, but I'd really like the web-based config (plus an apple one is pricey).
Who else makes simultaneous dual-band routers within $150, better yet $100 price range?
Thanks!
Thanks!
As an alternative underdog, this dual band router is $60 and its a clone of a Trendnet. I've had it for ~3 weeks and if its range is enough for your use, does very well. I run similar to your need, 2 GHz for b,g,n and 5 GHz for n only.
A brief review:
http://forums.smallnetbuilder.com/showpost.php?p=17631&postcount=6
