Hi
I have an Asus RT-N66U and work at home, connecting to the corporate VPN as required (using the windows VPN connection manager) . My partner is now also working for the same organisation and we have found that the router will only allow one VPN connection at a time. The only way to switch seems to be to reboot the router, which isn't ideal.
So a few questions:
Is there a way to allow both laptops to connect to the VPN using the stock firmware (3.0.0.4.380_7378) and if so how, and if not is there a way to "flush it" quickly so the other user can connect without rebooting the whole router?
If no to above, does Merlin support this?
Thanks for your help.
So a few questions:
