Site to Site VPN - with restrictions
TomT
Hi
I'm currently running firmware 376.45 (Merlin build) on my Asus rt-ac68u, but I am considering upgrading.
Is there any option for a Site to Site VPN in any build ?
If there is, once this is established can access be limited to specific IP Addresses on my LAN ?
Just to complicate this, I've been asked if we can route multiple connections down a Site to Site VPN.
If this is possible at all I'd like to be able to restrict users on the other end of the VPN from accessing parts of my local network.
My router will need to connect to them, but I want to control/restrict access.
You might need to install merlin firmware and add firewall configurations manually by editing files and such. It might just be easier to use a router like mikrotik routerOS or ubiquiti or pfsense as they have configurable firewalls and networking to achieve what you're asking.
assuming your 3rd question is about internet routing you can but you must set NAT/routes on the router and sometimes on the client machines. It has to be done via static routes.
Most business grade routers with VPN features allow you to device "who" can access "what" on each end of the tunnel. You define your local, and remote networks...on each end. Either the entire subnet...or you can get granular..narrowing the IPs. I'm not sure about a residential router with slightly modded firmware like Merlin...probably "not". But most biz grade models can do this right out of the box, no problem.
a lot of consumer routers are linux based which actually lets you use linux scripts if you can access the linux system. RMerlin's firmware lets you do that. But i was saying that using scripts are difficult. than again consumer routers are limited in their performance.
There are routers like pfsense which actually do well for what you want aside from the propietary ones i suggested. You could obviously use a linux server OS do the it and it would be better than using windows but that needs a lot of skill. when considering a business grade router dont use the cisco rv series as they would be slow for this not to mention lack of user control or to use scripts like a linux based router.
