Skynet Skynet adding multiple IP/Domains Whitelist
smithy
Can anyone please advice how to add multiple IPs/Domains to the white list at one go? I tried using a comma but didnt seem to work?
I couldn't see an example either in the example list given...
If you're comfortable with terminal edits, you could ssh in to the router, add the entries to
/jffs/addons/shared-whitelists/shared-Diversion-whitelist, then load Diversion and process the lists.
Did you try firewall import whitelist myfile.txt
