Skynet Skynet - console gaming
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
marko
Hi guys, is it possible to disable skynet only for console (PS4).
For example... my ps4 has address 192.168.1.111 and it does not work completely well if i add that ip to the whitelist, because... i play P2P game and all the time my console calls bunch of different IP addresses that all go (i assume) through the firewall process. So, instead of disabling completely skynet can i disable it for the whole console and all the traffic that goes through it? Thanks
