I’m running ASUS GT-AX6000 with latest MerlinWRT, and have Skynet, Diversion, and Unbound installed.
I ran a GRC ShieldsUP! scan on ports 0–1055 and noticed the following:
0 Ports Open
2 Ports Closed (80, 443)
1054 Ports Stealth
TruStealth: FAILED (because not all ports are stealth)
Full report:
This means the router is replying TCP RST (closed) on ports 80 and 443 to WAN scans, instead of dropping silently. Remote web GUI is disabled for WAN (I only access the UI from LAN on HTTPS port 8443).
Question:
Should Skynet enforce DROP (stealth) on WAN for all unused ports (including 80 and 443) when remote access is off? Or is this behavior coming from the stock ASUS firewall?
Would it make sense to add an option in Skynet to ensure full TruStealth mode by default?
Thanks!
0 Ports Open
1054 Ports Stealth
Full report:
- All ports except 80 and 443 are stealth.
- No unsolicited packets.
- No ping reply (ICMP blocked).
Question:
Thanks!
