Skynet Skynet error USB not found after USB drive substitution.
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
bigAboo
Hello. I remove my old drive and put new USB flash to usb3.0 port on my RT-AC68U. In "amtm" menu I see
When I hit 2 i see
and so on...
How can I solve this installation problem?
nbdwt73
When I hit 2 i see
and so on...
Did you format the new thumb drive before inserting it? If not then format on your computer then try again...
JaimeZX
Skynet was installed on your thumbdrive. If you remove the thumbdrive and put a different one, then Skynet isn't there anymore.
bigAboo
Yes, I'
Yes, i've format new drive, then make swap, then install Entware. And from the begining before all this steps amtm shows me that Skynet is installed.(
bigAboo
I though just like You but, but nope amtm shows me that Skynet is installed. This fact confuse me.
thelonelycoder
Part of the Furniture
amtm looks for the file /jffs/scripts/firewall to determine if Skynet is installed.
