Skynet Skynet multiple url feed?
BeachGuy
I've read through the various threads but can't find my answer. I have multiple urls/IPs that I want Skynet to use. I see [3] --> Malware Blacklist: [2] --> Change Filter List:
Input Custom Filter List URL:
Seems to take only 1 URL. I wrote a program to strip out IPs from the following but would like Skynet to do so that it automatically updates using it's process. It there a way to feed Skynet multiple URLs and maintain the list(s)? tia
# === ESSENTIAL SERVICES/Whitelist ===
# Google
216.239.32.0/19
172.217.0.0/16
142.250.0.0/15
108.177.0.0/16
74.125.0.0/16
173.194.0.0/16
8.8.8.8
8.8.4.4
# Microsoft
52.96.0.0/14
40.96.0.0/13
13.104.0.0/14
20.0.0.0/8
157.55.0.0/16
207.46.0.0/16
# Amazon AWS
52.0.0.0/11
54.0.0.0/9
3.0.0.0/8
# Apple
17.0.0.0/8
# GitHub/CDNs
151.101.0.0/16
199.232.0.0/16
185.199.108.0/22
140.82.112.0/20
# NTP
129.6.15.28
129.6.15.29
132.163.96.1
132.163.96.2
Quick and Nasty solution is to create the 'list' in something like pastebin.
If you select option 3 on Main Menu then option 2 ... as below ... you can point at the list on pastebin or wherever !!!
[You can change the Whitelist in Main Menu option 4 ... See below]
Remember to use the [raw] url with pastebin.
i.e. https://pastebin.com/raw/XxXxXxX
Thanks. I created a local txt file each list and them auto-imported them into Skynet on a cron.
