Skynet Skynet Not Working
jeffand123
I installed skynet multiple times cant figure out what the issue is.
Im running asus ac66 b1 router latest firmware installed the only thing im using different in my setup im accessing the internet through wifi adapter sharing that through ethernet adapter then through the router wan then to my devices.
Everything works as expected but when I view my firewall stats it shows nothing blocked?
I used nmap with the following results:
Nmap done: 1 IP address (1 host up) scanned in 1.01 seconds
root@unknown:~# nmap -p- 192.168.50.0/24
Starting Nmap 7.80SVN ( https://nmap.org ) at 2021-12-14 00:57 CST
Nmap scan report for RT-AC66U_B1-6E70 (192.168.50.1)
Host is up (0.0078s latency).
Not shown: 65526 closed ports
PORT STATE SERVICE
53/tcp open domain
80/tcp open http
139/tcp open netbios-ssn
445/tcp open microsoft-ds
3702/tcp open ws-discovery
5657/tcp open unknown
7788/tcp open unknown
18017/tcp open unknown
37008/tcp open unknown
MAC Address: XXXXXXXXXXXX (Asustek Computer)
How do I figure out the correct way to go about fixing or figuring out why it wont block anything???
The Skynet developer is no longer around on this forum , you'll find him on GitHub.
If you look below your post you'll find "Similar Threads " one of which is :
SkyNet zero counters
Isnt skynet suppose to block inbound or outbound ports that are vulnerable 445 is one I don't want open
The other problem when I look at the stats it's not blocking anything .
It is enabled I don't understand why it's not doing anything.
Can someone please give me a starting point on how to correctly use skynet?
The correct way to use Skynet? Just install.
So weird out of no where I reinstalled yesterday and it is showing stats correctly and working
Hopefully last question
I cant find the option to change the lists there was a small medium and large list option
Not the option to import via url option I no where that is.
I might be thinking of separate program I looked at so many settings on different apps in amtm so forgive if im wrong.
