Skynet Skynet put modem in bridge mode disable cg nat.
jeffand123
Ok first would like to wish everyone in snbforum a Merry Christmas and a Happy New Year!!!
I have RT-AC66U B1 running 386.3_2 firmware.
I'm using a usb wifi adapter on linux in shared mode thru Ethernet to the router.
Here's my skynet error:
Private WAN IP Detected 10.42.0.2 - Please Put Your Modem In Bridge Mode / Disable CG-NAT
Because I don't have a modem at all what would be the easiest fix?
Is there a way to change the Ip in linux to make it have an Ip that would be compatible?
Any fix to get skynet working properly I would be grateful.
Ok but it's this probably the reason skynet is not blocking incoming or outgoing connections ?
I still have not found any other reason why skynet is not filtering anything?
It's likely to be the reason it's not showing any incoming blocks because they will be blocked by the Linux machine. Whether it should be showing any outgoing blocks will depend on what you're blocking and what your clients are doing.
Ok makes sense!
Is there a skynet blocked site I can try that not so horrible if it loads?
Just to test outbound blocking.
I don't use Skynet so I don't know what options you have there. But if you have an option to block porn it would then be easy to check that.
