Skynet show inbound block on Digital TV Vlan300
poudenes
Hi All,
I have a Asus GT AX 11000 router. Also digital TV and configured the IPTV in the router. VLAN 300.
Skynet show now those blocks on the VLAN300? It looks strange because VLAN300 is a closed network with my provider for the TV.
This inbound block must show the external IP of my internet connection right?
DST IP is my external IP from my internet connection. Hide it :)
Jan 30 10:10:14 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:2c SRC=183.136.225.32 DST=87.208.XXX.XXX LEN=44 TOS=0x00 PREC=0x00 TTL=113 ID=0 PROTO=TCP SPT=16487 DPT=3522 SEQ=556492272 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Jan 30 10:10:32 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:2c SRC=79.124.58.18 DST=87.208.XXX.XXX LEN=44 TOS=0x00 PREC=0x00 TTL=248 ID=10860 PROTO=TCP SPT=40362 DPT=4171 SEQ=1566258544 ACK=0 WINDOW=1025 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Jan 30 10:10:46 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:28 SRC=192.241.195.49 DST=87.208.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=55263 DPT=1400 SEQ=729569631 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan 30 10:10:48 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:2c SRC=152.32.181.210 DST=87.208.XXX.XXX LEN=44 TOS=0x00 PREC=0x00 TTL=55 ID=0 DF PROTO=TCP SPT=34622 DPT=1883 SEQ=2913629055 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (02040584) MARK=0x8000000
Jan 30 10:10:51 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:28 SRC=37.44.238.102 DST=87.208.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=54321 PROTO=TCP SPT=43266 DPT=8728 SEQ=2807200270 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan 30 10:10:54 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:28 SRC=92.63.197.224 DST=87.208.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=251 ID=40352 PROTO=TCP SPT=47174 DPT=21426 SEQ=878035269 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan 30 10:10:56 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:2c SRC=198.235.24.200 DST=87.208.XXX.XXX LEN=44 TOS=0x00 PREC=0x00 TTL=252 ID=54321 PROTO=TCP SPT=51243 DPT=56222 SEQ=1308067282 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Jan 30 10:10:58 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:2c SRC=198.235.24.67 DST=87.208.XXX.XXX LEN=44 TOS=0x00 PREC=0x00 TTL=61 ID=54321 PROTO=TCP SPT=52421 DPT=4433 SEQ=3148945838 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Jan 30 10:11:06 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:34 SRC=43.157.198.106 DST=87.208.XXX.XXX LEN=52 TOS=0x00 PREC=0x00 TTL=52 ID=34434 DF PROTO=TCP SPT=35458 DPT=4200 SEQ=1281216118 ACK=0 WINDOW=61690 RES=0x00 SYN URGP=0 OPT (020405900103030801010402) MARK=0x8000000
Jan 30 10:11:09 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:28 SRC=80.94.95.249 DST=87.208.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=5401 PROTO=TCP SPT=61000 DPT=9259 SEQ=1028406885 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan 30 10:11:19 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:10:00:2c SRC=71.6.158.166 DST=87.208.XXX.XXX LEN=44 TOS=0x10 PREC=0x00 TTL=113 ID=32976 PROTO=TCP SPT=29011 DPT=10243 SEQ=1058805439 ACK=0 WINDOW=26349 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Jan 30 10:11:28 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:28 SRC=94.156.68.205 DST=87.208.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=251 ID=54321 PROTO=TCP SPT=43477 DPT=2333 SEQ=2472201440 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan 30 10:11:30 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:2c SRC=94.102.61.47 DST=87.208.XXX.XXX LEN=44 TOS=0x00 PREC=0x00 TTL=251 ID=54321 PROTO=TCP SPT=54336 DPT=3146 SEQ=2122858830 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Jan 30 10:11:45 ASUS kernel: [BLOCKED - INBOUND] IN=vlan300 OUT= MAC=50:ed:3c:ef:7a:45:00:0e:00:00:00:01:08:00:45:00:00:28 SRC=162.243.136.53 DST=87.208.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=42060 DPT=5269 SEQ=3373993488 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
That does look odd. It appears that vlan300 is your internet connection not IPTV. Was "VLAN30" a typo in your post?
Post a screenshot of your IPTV settings.
VLAN30 was typo.
handmatige instelling = Manual settings
Uitgeschakeld = disabled
OK. So what you are seeing is normal then. Your router's WAN interface is vlan300 which is not a closed TV network as you said it was.
I was thinking that VLAN always is a closed network over a network (my internet). But thanks that this is ok and everything is normal :)
