Skynet Skynet wont update
smithy
When updating skynet keep getting this error when doing it:
Updating chart.js Failed
Updating chartjs-plugin-zoom.js Failed
Updating hammerjs.js Failed
Updating skynet.asp Failed
Updating firewall.sh Failed
Any ideas?
Mogsy
Try running debug option 12 and print debug info
smithy
18/18 tests sucessful and all passed. I have a feeling this is because i am on 384.19 and its a outdated certificate/SSL issue. I had to disable something last time to update diversion (echo insecure >> $HOME/.curlrc). AMTM is also not now updating either.
AMTM gives
* opkg_download: Failed to download https://bin.entware.net/aarch64-k3.10/Packages.gz, wget returned 5.
Wallace_n_Gromit
When I try to open skynet (press 2) to begin the update to the latest version I get this:
Maybe time for a fresh reinstall of amtm?
Router Firewall And Security Enhancements #
# By Adamm - https://github.com/Adamm00/IPSet_ASUS #
# 19/10/2021 - v7.2.8
Router Model;
Skynet Version; (19/10/2021) (cd9e05f9b3897f144dd71260906a761a)
iptables v1.4.15 - (eth0 @ 192.168.xxx.xxx)
ipset v7.6, protocol version: 7
IP Address; (xxx.xxx.xxx.xxx)
FW Version; 386.9_0 (Jan 6 2023) (4.1.27)
Install Dir; /tmp/mnt/AsusRTAC86U/skynet (513.7M / 14.0G Space Available)
/jffs/scripts/firewall: line 40: arithmetic syntax error
Viktor Jaep
You might be able to force an update with this command? Give it a whirl?
firewall update -f
Wallace_n_Gromit
firewall update -f
thank you, seems to have updated!
When I try to press 2 for Skynet, seems to result in the same issue I had earlier though . Have to remember that command for updates... and probably other command line commands for future skynet config changes.
