CommanderZ82
Hi forum
I am new here inside and I hope to get help from you guys.
I have installed an PE-AC88 in my PC. WIth my former ISP, I reached in AC 5GHz mode almost 900 MBit/s ( It is an 1GBit/s connection), which is quite good for Wifi.
Now, after changing the ISP, I am running an FritzBox 5490 as Modem. I connected a EA-AC87 in AP mode ( Firmware Version:3.0.0.4.374_2849) .
If I connect my PC with Ethernet to the AP, I will rech about 950 MBit/s (up/down).
Connect via Wifi, the max. speed is around 500 MBit/s. (Try already to hane postion (last setup was 2m distance between AP and PC)
I checked forums and all, but I could not increase the speed. Also ASUS support is not helpful.
I found out, that in the in the Wireless LOG, the folloing is listed:
MAC Associated Authorized RSSI Tx rate Rx rate Connect Time
F4:E1:1E:09:22:E7 YES YES -62 dBm 120 150 33:2013:-118754
D6:8D:4A:E6:6B:26 YES YES -58 dBm 390 433 11:718:-39567
A4:45:19:FB:63:29 YES YES -73 dBm 390 7 00:14:44
2C:FD:A1:CE:F6:E4 YES YES -47 dBm 1170 1300 00:09:51
Last entry is my PC with PCE-AC88. Does I interpret right, that the speed, given by the AP is 1170 MBit/s? (Tx rate). So that means, that the problem seems to be in the network card? It is prooble to connest the 4 antennas of the PCE-AC88 wrongly? ( order of connected antennas?)
Does anyone have an idea where the bottle neck is? Doea anyone have the firmware, which was already written in other threads long time ago?
Thanks in advance
Thanks in advance
