Slow VPN on RT-BE92U
PuraVida
The setup is, in addition to the RT-BE92U is gigabit fiber coming from a Huawei OptiXstar EG8041X6-10 ONT. There are no Entware or AMTM add ons. The router see in the mid 900s and minus VPN that's essentially what a client gets. But connect with VPN and speeds to clients drop into the mid 100s. I have two VPN providers, Surfshark and Nord. I have tried OVPN UDP and Wireguard from both providers. Speeds vary as you'd expect but no drastic improvement. I've disabled the router firewall with no joy there either. I'm on the latest Merlin firmware, 3006.102.6. While the ONT has wireless capabilities the ONT is running in bridge mode. The ISP by default uses non routable addresses for client but public IPs are available for a small fee which I have added. What I have no way of knowing is how, even in bridge mode, routing is done. When the ISP put the ONT in bridge mode it did not disable DHCP or wireless. This is my first experience with Huawei ONTs and know little about them. As an FYI, I'm in Costa Rica.
I would appreciate any ideas or thoughts
The ONT state is unrelated to your VPN speed issue. Bridge or Gateway - doesn't matter for your VPN Client. Enable the firewall on your ASUS. VPN speed is not guaranteed. There are external limiting factors unrelated to your hardware capabilities. Test with x86 hardware (VPN Client application on a PC) to the same servers and see if the speed goes any higher. If it doesn't - the servers you connect to limit the bandwidth.
