lazydrunksmurf
Due to some changes in my set up, I now need faster wifi 5ghz with my vpn (PIA). I don't think it's unreasonable based on some tests.. I am getting fast wifi with no vpn and fast vpn through Ethernet, the problem is when I use wifi and VPN, the speeds are dramatically slower.
Tests (several tests conducted, trying to give a rough average).
When I say "VPN" below, it is done through the admin console and the device is routed through VPN (forget about the PIA app, I didn't use that at all in the tests below). I also tested with speedtest and let it choose the server in some tests and in some tests I manually set the server so that we are comparing apples to apples. There was not much difference in speed with the selection of servers since I let it choose one and manually set the other on another device for comparison.
1. Cell phone wifi 5ghz no vpn: 49 down. [GOOD]
2. Cell phone wifi 5ghz with VPN: 9 down (anywhere from 4-14 down). [PROBLEM]
3. Laptop wifi 5ghz no vpn: 49 down. [GOOD]
4. Laptop wifi with VPN: 10 down (anywhere from 7-15). [PROBLEM]
5. Laptop Ethernet with VPN: 44 down. [GOOD]
Analysis/things tried:
Test 1 and 3 tell me that there is no hardware issue either with my devices or with the router. Test 5 tells me that PIA is not being slow. Tests 2 and 4 are what I seek your help with. Based on all these tests, I think it is reasonable to expect a higher speed with wifi and vpn.
I read that turning off Lz compression can help (I don't really know what this is, but I tried it anyway)- it didn't help.
I have power cycled my DSL modem (bridge mode), and the ASUS router- didn't help.
Not really sure what else to check, I am not a networking guru.. given this, there may be information that I am unaware that you may need to help me. So, if there is something I can provide, feel free to let me know
Thanks for your help in advance!
- Router: RT-AC1750_B1 attached to a DSL modem running in bridge mode.
- Merlin: 380.68
- Internet: DSL 50 down 10 up, perfect speeds (with no vpn).
- VPN: PIA, openVPN with device specific selective routing through VPN.
- Devices (relevant to this discussion): 1 cell phone, 1 windows laptop- these were tested with and without vpn and the laptop was tested with and without vpn both with wifi and Ethernet.
