I cannot figure out why I am not getting full speeds on 5ghz or 2.4ghz on this router. When I use the built in router in my modem, I get full speeds, but when I put this router in between, the speeds are max 40mbps, when I should be getting 150mbps.
It has something to do with the settings, because my modem has been put into bridge mode and only using this router.
I have tried to play around with all the settings, currently using only 5ghz and nothing has worked. QOS is disabled.
What else can I try?
Thanks.
Thanks.
