1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Slow WiFi speeds with RT-AC68R vs ethernet
Discussion in 'ASUS AC Routers & Adapters' started by teohenwhy, Oct 23, 2019.
  1. teohenwhy
    teohenwhy New Around Here
    Apr 20, 2016
    6
    My wifi speeds are only around 250mbps but with ethernet im getting around 600mbps. What would cause my wifi speeds to be less than half what my ethernet is giving me? TIA for any info.
  2. teohenwhy
    Apr 20, 2016
    6
    CTF+ FA enabled. Running Merlin 384.13 FW.
  3. Greg72
    Greg72 Regular Contributor
    Sep 24, 2019
    182
    Central Illinois
    What speedtest app are you using? Make sure that you have made adjustments in the network adapter to turn off stuff like Large Packet Offload, etc. It took me a bit to get my desktop with a USB 3.0 to Ethernet up to the max speed, along with WiFi. I have Xfinity’s gig service and the RT-68U. I am getting around 525/38 on my iPad Pro. I do have Diversion running on[ my Merlin install.
  4. teohenwhy
    Apr 20, 2016
    6
    I used Speedtest.net as well as Comcast’s speedtest. I figured out part of my issue and now it’s just a slower WiFi signal that I’m having.
  5. Val D.
    Val D. Very Senior Member
    Jun 16, 2019
    799
    Great White North
    About 600Mbps WiFi throughput is possible only with 3x3 AC client, quiet WiFi networks around and close to the router, or 1300Mbps link speed. With 2x2 AC clients (866Mbps link speed) you can get about 400Mbps, with 1x1 AC (433Mbps link speed) clients about 200mbps.
  6. teohenwhy
    Apr 20, 2016
    6
    I
    i actually resolved the issue and now I’m getting over 500Mbps download on WiFi now. I just had to reset everything to defaults after upgrading the FW.
  7. Val D.
    Jun 16, 2019
    799
    Great White North
    Good. The speed is excellent over WiFi. Don't touch anything now... :)
