So confused!!
edenhope
Hello
I have a thoroughbred analysis program I have written in Visual Basic 6. When I first run the program it access many files (jockey names, horse histories. etc.). Then the program constantly accesses many other files as it runs.
All these files I store in a folder called WestAust which is stored on a portable HDD that I connect to whichever computer I am using, sometimes on my laptop, sometimes on my desktop.
When the program first runs it searches for the WestAust folder using FileSystemObject and sets a global drive letter called MainDrive.
I would like this folder to be in an independent place so I can access it from any where I am in my house (so I do not use portable HDD).
I have purchased a Lenovo px2-300d NAS.
Please! how do I configure my Lenovo NAS so my program finds the folder on the network and I can access, change and add new files as the program runs from any computer in my house?
I am running Windows 10
Thank you to any one that helps me.
Steven
I assume you use Windows?
If so, you need to either Map a network drive or Add a network location in File Explorer under This PC.
Thank you for your reply.
I did map the drive and assigned it Z:. But my program can only find drives attached to my computer not network drives.
Steven
I think you need to post your question on a site that's more geared towards Visual Basic as your question is specifically related to a VB programming problem rather than a network/NAS issue.
Steven
If your machine can access the network location/files, then your VB program should be able to. Check your programming (?).
OE
Steven
I presume you're using SMB/Samba on the NAS to create the shares? Have you made sure to allow access to those shares or at least folders without a username and password?
As some others have pointed out here, it seems to be a programming issue if you've done the above, as all software I use can see my network drives. In fact, most programs think they're a local drive, due to the drive letter. A network location on the other hand doesn't have a drive letter, so some programs can't see those.
Just as an example, this is a simple drive benchmarking software and as you can see, it clearly sees my network shares just as any other drive.
A bit older way:
If the search routine can't handle non-local drive mappings, then maybe you should move to a configuration file setup where you access the data directory directly based on the config entry. (Or write a new routine that can handle it)
Searching every drive for a specific data folder doesn't seem terribly efficient IMO, but if it works for you....
