garycnew
NOTE: After finally being convinced by the Entware & OpenWRT Developers that neither Build Environment was meant to be Compiled Natively on a Router (Neutered C Libraries), I decided to pursue this Cross-Compile Nyx (Tor Command-Line Monitor) Entware Package via Debian Live DVD solution; which, is presumably a bit slower, but ultimately successful. It wasn't too terrible after finding the right cross-compiling platform and combining a few different build references.
Requirements/Assumptions:
Cross-Compiling Host Machine:
1. Plenty of Physical Memory (RAM)
2. Debian Live (Testing) DVD
3. Flash Drive >= 32GB (Preferably USB 3.0/3.1)
Nyx (Tor Command-Line Monitor) Installation Machine:
1. An Asuswrt-Merlin Compatible Router (i.e., Asus RT-AC66U)
2. Asuswrt-Merlin Compatible Firmware (i.e., 384.19)
3. Formated JFFS Partition and Enabled JFFS Custom Scripts and Configs
4. Entware installed on USB 3.0 Interface Device via Asuswrt-Merlin Terminal Menu (AMTM) with Swap File created
NOTE: Not sure if it matters... At the time of this writing, Debian Bullseye (Testing) Live DVD contained the same package versions as the current Entware repository, opposed to the Debian Buster (Stable) Live DVD, so we opted to use the Debian Bullseye (Testing) Live DVD.
### Download & Burn Debian Live (Testing) DVD ###
### Boot Debian Live (Testing) DVD on the Cross-Compiling Host Machine ###
Our Cross-Compiling Host Machine required the [F12] key to be pressed during boot to enter into the Boot Menu and select the Debian Live (Testing) DVD. Make sure you setup and have Internet access on the Cross-Compiling Host Machine.
### Open Terminal ###
### Mount Flash Drive (Repeat after each DVD Boot) ###
### Download & Install Build System (Repeat after each DVD Boot) ###
### Clone, Setup, & Make Entware Build Env ###
### Download, Prepare, & Compile Test Package from OpenWRT Feed ###
### Download & Prepare OpenWRT Feed Package modified for Entware (When Available) ###
### It is unnecessary to edit the Makefile as Entware & PYPI take care of the configuration for us ###
### Select nyx for [M]odular inclusion under the SECTION => CATEGORY => SUBMENU of menuconfig ###
### Compile OpenWRT Feed Package modified for Entware ###
### SFTP & SSH Nyx (Tor Command-Line Monitor) Packages & Dependencies to the Installation Machine(s) ###
### (Optional) Remove Nyx (Tor Command-Line Monitor) & Dependencies ###
Congratulations! You've Cross-Compiled an Nyx (Tor Command-Line Monitor) Entware Package via Debian Live (Testing) DVD! The Possibilities are Endless with Good-Times Ahead!
References:
$ curl -L -O -C - http://cdimage.debian.org/cdimage/unofficial/non-free/cd-including-firmware/weekly-live-builds/amd64/iso-hybrid/debian-live-testing-amd64-gnome+nonfree.iso
$ mount /dev/sdb1 /media/user/SanDiskSDCZ
$ cd /media/user/SanDiskSDCZ/
$ sudo apt-get update
$ sudo apt-get install git-core build-essential libssl-dev libncurses5-dev unzip gawk zlib1g-dev
$ sudo apt-get install python2 wget
$ git clone https://github.com/Entware/Entware.git
$ cd Entware
# Update OpenWRT Feeds
$ ./scripts/feeds update -a
# Symlink Packages (Repeat after each DVD Boot)
$ make package/symlinks
# Copy the config specific to your Architecture and Kernel versions
$ cp configs/armv7-2.6.config .config
$ make tools/install && make toolchain/install && make target/compile
or
#$ make -j1 V=sc tools/install
#$ make -j1 V=sc toolchain/install
#$ make -j1 V=sc target/compile
#$ ./scripts/feeds install screen
or
$ make -j1 V=sc package/screen/download
$ make -j1 V=sc package/screen/check
$ find package/ -iname "*screen*"
package/feeds/packages/screen
$ make -j1 V=sc package/screen/prepare
$ make -j1 V=sc package/screen/compile
#$ make -j1 V=sc package/screen/install
#$ make package/index
$ find bin/ -iname "*screen*"
bin/targets/armv7-2.6/generic-glibc/packages/screen_4.8.0-2_armv7-2.6.ipk
#$ ./scripts/feeds install nyx
or
$ make -j1 V=sc package/feeds/packages/nyx/download
$ make -j1 V=sc package/feeds/packages/nyxcheck
$ find package/ -iname "*nyx*"
$ make menuconfig
define Package/nyx
SECTION:=admin
CATEGORY:=Administration
URL:=https://nyx.torproject.org/
TITLE:=Terminal status monitor for Tor
DEPENDS:=+python3 +python3-stem
endef
$ make -j1 V=sc package/feeds/packages/nyx/prepare
$ make -j1 V=sc package/feeds/packages/nyx/compile
#$ make -j1 V=sc package/feeds/packages/nyx/install
$ find bin/ -iname "*nyx*"
bin/targets/armv7-2.6/generic-glibc/packages/nyx_2.1.0-2_armv7-2.6.ipk
$ cd bin/targets/armv7-2.6/generic-glibc/packages/
$ ls
python3-stem_1.8.0-2_armv7-2.6.ipk
$ sftp [email protected]
sftp> cd /tmp/mnt/SanDiskSDHC/nyx/
sftp> put nyx_2.1.0-2_armv7-2.6.ipk
sftp> put python3-stem_1.8.0-2_armv7-2.6.ipk
$ ssh [email protected]
# cd /tmp/mnt/SanDiskSDHC/
# opkg install ./nyx/*
# opkg list-installed|grep -i nyx
nyx - 2.1.0-2
# opkg files nyx
Package nyx (2.1.0-2) is installed on root and has the following files:
/opt/lib/python3.9/site-packages/nyx-2.1.0-py3.9.egg-info/top_level.txt
/opt/lib/python3.9/site-packages/nyx/curses.pyc
/opt/lib/python3.9/site-packages/nyx-2.1.0-py3.9.egg-info/SOURCES.txt
/opt/lib/python3.9/site-packages/nyx/starter.pyc
/opt/lib/python3.9/site-packages/nyx/panel/config.pyc
/opt/lib/python3.9/site-packages/nyx/arguments.pyc
/opt/lib/python3.9/site-packages/nyx/settings/dedup.cfg
/opt/lib/python3.9/site-packages/nyx/panel/graph.pyc
/opt/lib/python3.9/site-packages/nyx-2.1.0-py3.9.egg-info/dependency_links.txt
/opt/lib/python3.9/site-packages/nyx/panel/__init__.pyc
/opt/lib/python3.9/site-packages/nyx/settings/attributes.cfg
/opt/lib/python3.9/site-packages/nyx/panel/connection.pyc
/opt/lib/python3.9/site-packages/nyx/menu.pyc
/opt/bin/nyx
/opt/lib/python3.9/site-packages/nyx-2.1.0-py3.9.egg-info/entry_points.txt
/opt/lib/python3.9/site-packages/nyx-2.1.0-py3.9.egg-info/PKG-INFO
/opt/lib/python3.9/site-packages/nyx/panel/header.pyc
/opt/lib/python3.9/site-packages/nyx/__init__.pyc
/opt/lib/python3.9/site-packages/nyx/panel/interpreter.pyc
/opt/lib/python3.9/site-packages/nyx/panel/torrc.pyc
/opt/lib/python3.9/site-packages/nyx/tracker.pyc
/opt/lib/python3.9/site-packages/nyx/panel/log.pyc
/opt/lib/python3.9/site-packages/nyx/popups.pyc
/opt/lib/python3.9/site-packages/nyx/log.pyc
/opt/lib/python3.9/site-packages/nyx-2.1.0-py3.9.egg-info/requires.txt
# opkg info nyx
Package: nyx
Version: 2.1.0-2
Depends: libc, libssp, librt, libpthread, python3, python3-stem
Status: install user installed
Architecture: armv7-2.6
Installed-Time: 1628407667
# /opt/bin/nyx -v
nyx version 2.1.0 (released January 12, 2019)
# /opt/bin/nyx -i 9051
# opkg remove nyx python3-stem python3 python3-decimal python3-lzma liblzma python3-asyncio python3-codecs python3-dbm libdb47 python3-cgitb python3-cgi python3-openssl python3-distutils python3-xml libexpat python3-sqlite3 libsqlite3 python3-gdbm libgdbm python3-readline python3-urllib python3-email python3-multiprocessing python3-logging python3-pydoc python3-ctypes python3-ncurses python3-unittest python3-light libbz2 libffi python3-base libpython3
References:
http://bin.entware.net/armv7sf-k2.6/
https://packages.debian.org/search?keywords=search
https://oldwiki.archive.openwrt.org/about/toolchain
https://oldwiki.archive.openwrt.org/doc/howto/buildroot.exigence
https://oldwiki.archive.openwrt.org/doc/howto/build.a.package
https://github.com/Entware/Entware/wiki/How-to-add-a-new-package
https://github.com/Entware/Entware-ng/wiki/Using-gcc-%28native-compilation%29
https://github.com/torproject/nyx
https://pypi.org/project/nyx/
