garycnew
NOTE: After finally being convinced by the Entware & OpenWRT Developers that neither Build Environment was meant to be Compiled Natively on a Router (Neutered C Libraries), I decided to pursue this Cross-Compile xxHash Entware Package via Debian Live DVD solution; which, is presumably a bit slower, but ultimately successful. It wasn't too terrible after finding the right cross-compiling platform and combining a few different build references.
Requirements/Assumptions:
Cross-Compiling Host Machine:
1. Plenty of Physical Memory (RAM)
2. Debian Live (Testing) DVD
3. Flash Drive >= 32GB (Preferably USB 3.0/3.1)
xxHash Installation Machine:
1. An Asuswrt-Merlin Compatible Router (i.e., Asus RT-AC66U)
2. Asuswrt-Merlin Compatible Firmware (i.e., 384.19)
3. Formated JFFS Partition and Enabled JFFS Custom Scripts and Configs
4. Entware installed on USB 3.0 Interface Device via Asuswrt-Merlin Terminal Menu (AMTM) with Swap File created
NOTE: Not sure if it matters... At the time of this writing, Debian Bullseye (Testing) Live DVD contained the same package versions as the current Entware repository, opposed to the Debian Buster (Stable) Live DVD, so we opted to use the Debian Bullseye (Testing) Live DVD.
### Download & Burn Debian Live (Testing) DVD ###
### Boot Debian Live (Testing) DVD on the Cross-Compiling Host Machine ###
Our Cross-Compiling Host Machine required the [F12] key to be pressed during boot to enter into the Boot Menu and select the Debian Live (Testing) DVD. Make sure you setup and have Internet access on the Cross-Compiling Host Machine.
### Open Terminal ###
### Mount Flash Drive (Repeat after each DVD Boot) ###
### Download & Install Build System (Repeat after each DVD Boot) ###
### Clone, Setup, & Make Entware Build Env ###
### Download, Prepare, & Compile Test Package from OpenWRT Feed ###
### Download & Prepare OpenWRT Feed Package modified for Entware (When Available) ###
### Edit the Makefile to use the /opt directory prefix ###
### Select xxhash for [M]odular inclusion under the SECTION => CATEGORY => SUBMENU of menuconfig ###
### Compile OpenWRT Feed Package modified for Entware ###
### SFTP & SSH xxhash Package to xxHash Installation Machine(s) ###
Congratulations! You've Cross-Compiled a xxHash Entware Package via Debian Live (Testing) DVD! The Possibilities are Endless with Good-Times Ahead!
References:
### Full Edited xxhash Makefile ###
$ curl -L -O -C - http://cdimage.debian.org/cdimage/unofficial/non-free/cd-including-firmware/weekly-live-builds/amd64/iso-hybrid/debian-live-testing-amd64-gnome+nonfree.iso
$ sudo -p /media/user/SanDiskSDCZ
$ sudo mount /dev/sdb1 /media/user/SanDiskSDCZ
$ cd /media/user/SanDiskSDCZ/
$ sudo apt-get update
$ sudo apt-get install git-core build-essential libssl-dev libncurses5-dev unzip gawk zlib1g-dev
$ sudo apt-get install python2 wget
$ git clone https://github.com/Entware/Entware.git
$ cd Entware
# Update OpenWRT Feeds
$ ./scripts/feeds update -a
# Symlink Packages (Repeat after each DVD Boot)
$ make package/symlinks
# Copy the config specific to your Architecture and Kernel versions
$ cp configs/armv7-2.6.config .config
$ make tools/install && make toolchain/install && make target/compile
or
#$ make -j1 V=sc tools/install
#$ make -j1 V=sc toolchain/install
#$ make -j1 V=sc target/compile
#$ ./scripts/feeds install screen
or
$ make -j1 V=sc package/screen/download
$ make -j1 V=sc package/screen/check
$ find package/ -iname "*screen*"
package/feeds/packages/screen
$ make -j1 V=sc package/screen/prepare
$ make -j1 V=sc package/screen/compile
#$ make -j1 V=sc package/screen/install
#$ make package/index
$ find bin/ -iname "*screen*"
bin/targets/armv7-2.6/generic-glibc/packages/screen_4.8.0-2_armv7-2.6.ipk
#$ ./scripts/feeds install xxhash
or
$ make -j1 V=sc package/feeds/packages/xxhash/download
$ make -j1 V=sc package/feeds/packages/xxhash/check
$ find package/ -iname "*xxhash*"
$ diff package/feeds/packages/xxhash/Makefile.orig package/feeds/packages/xxhash/Makefile
53,58c53,58
< $(INSTALL_DIR) $(1)/usr/include
< $(CP) $(PKG_BUILD_DIR)/*.h $(1)/usr/include
< $(INSTALL_DIR) $(1)/usr/lib
< $(CP) $(PKG_BUILD_DIR)/libxxhash.so $(1)/usr/lib
< $(INSTALL_DIR) $(1)/usr/lib/pkgconfig
< $(CP) $(PKG_BUILD_DIR)/libxxhash.pc.in $(1)/usr/lib/pkgconfig
> $(INSTALL_DIR) $(1)/opt/include
> $(CP) $(PKG_BUILD_DIR)/*.h $(1)/opt/include
> $(INSTALL_DIR) $(1)/opt/lib
> $(CP) $(PKG_BUILD_DIR)/libxxhash.so $(1)/opt/lib
> $(INSTALL_DIR) $(1)/opt/lib/pkgconfig
> $(CP) $(PKG_BUILD_DIR)/libxxhash.pc.in $(1)/opt/lib/pkgconfig
62,65c62,65
< $(CP) $(PKG_BUILD_DIR)/libxxhash.so* $(1)/usr/lib
< $(INSTALL_DIR) $(1)/usr/bin
< $(INSTALL_BIN) $(PKG_BUILD_DIR)/xxh*sum $(1)/usr/bin/
> $(CP) $(PKG_BUILD_DIR)/libxxhash.so* $(1)/opt/lib
> $(INSTALL_DIR) $(1)/opt/bin
> $(INSTALL_BIN) $(PKG_BUILD_DIR)/xxh*sum $(1)/opt/bin/
$ make menuconfig
define Package/xxhash/Default
SECTION:=utils
CATEGORY:=Utilities
URL:=http://www.xxhash.com
endef
$(call Package/xxhash/Default)
TITLE:=Extremely fast hash algorithm
#DEPENDS:=+make +gcc
endef
$ make -j1 V=sc package/feeds/packages/xxhash/prepare
$ make -j1 V=sc package/feeds/packages/xxhash/compile
#$ make -j1 V=sc package/feeds/packages/xxhash/install
$ find bin/ -iname "*xxhash*"
bin/targets/armv7-2.6/generic-glibc/packages/xxhash_0.8.1-1_armv7-2.6.ipk
$ cd bin/targets/armv7-2.6/generic-glibc/packages/
$ sftp [email protected]
sftp> cd /tmp/mnt/SanDiskSDHC/
sftp> put xxhash_0.8.1-1_armv7-2.6.ipk
$ ssh [email protected]
# cd /tmp/mnt/SanDiskSDHC/
# opkg install ./xxhash_0.8.1-1_armv7-2.6.ipk
# opkg list-installed|grep -i xxhash
xxhash - 0.8.1-1
# opkg files xxhash
Package xxhash (0.8.1-1) is installed on root and has the following files:
/opt/bin/xxhsum
/opt/bin/xxh64sum
/opt/bin/xxh128sum
/opt/bin/xxh32sum
/opt/lib/libxxhash.so.0
/opt/lib/libxxhash.so.0.8.1
# opkg info xxhash
Package: xxhash
Version: 0.8.1-1
Depends: libc, libssp, librt, libpthread
Status: install user installed
Architecture: armv7-2.6
Installed-Time: 1643162375
# /opt/bin/xxhsum -h
xxhsum 0.8.1 by Yann Collet
Print or verify checksums using fast non-cryptographic algorithm xxHash
# /bin/echo "Non-Cryptographic" | /opt/bin/xxhsum
a437783b51578b0f stdin
References:
http://bin.entware.net/armv7sf-k2.6/
https://packages.debian.org/search?keywords=search
https://oldwiki.archive.openwrt.org/about/toolchain
https://oldwiki.archive.openwrt.org/doc/howto/buildroot.exigence
https://oldwiki.archive.openwrt.org/doc/howto/build.a.package
https://github.com/Entware/Entware/wiki/How-to-add-a-new-package
https://github.com/Entware/Entware-ng/wiki/Using-gcc-%28native-compilation%29
https://github.com/Cyan4973/xxHash
https://src.fedoraproject.org/rpms/xxhash/blob/f33/f/xxhash.spec
$ cat feeds/packages/utils/xxhash/Makefile
# Copyright (C) 2006-2015 OpenWrt.org
# This is free software, licensed under the GNU General Public License v2.
# See /LICENSE for more information.
include $(TOPDIR)/rules.mk
PKG_NAME:=xxhash
PKG_VERSION:=0.8.1
PKG_RELEASE:=1
PKG_SOURCE:=$(PKG_NAME)_$(PKG_VERSION).tar.gz
PKG_SOURCE_URL:=https://github.com/Cyan4973/xxHash/archive/v$(PKG_VERSION)
PKG_HASH:=3bb6b7d6f30c591dd65aaaff1c8b7a5b94d81687998ca9400082c739a690436c
# The source for the library (xxhash.c and xxhash.h) is BSD
# The source for the command line tool (xxhsum.c) is GPLv2+
PKG_MAINTAINER:=https://github.com/Cyan4973/xxHash
PKG_LICENSE:=BSD and GPLv2+
PKG_LICENSE_FILES:=COPYING
include $(INCLUDE_DIR)/package.mk
SECTION:=utils
CATEGORY:=Utilities
endef
endef
define Package/xxhash/description
xxHash is an Extremely fast Hash algorithm, running at RAM speed
limits. It successfully completes the SMHasher test suite which
evaluates collision, dispersion and randomness qualities of hash
functions. Code is highly portable, and hashes are identical on all
platforms (little / big endian).
endef
define Build/Prepare
rm -rf $(PKG_BUILD_DIR)/
mkdir -p $(PKG_BUILD_DIR)/
$(TAR) -xzf $(DL_DIR)/$(PKG_SOURCE) -C $(PKG_BUILD_DIR) --strip 1
endef
define Build/InstallDev
endef
define Package/xxhash/install
endef
$(eval $(call BuildPackage,xxhash))
