[SOLVED] Openvpn and Encryption cipher = None: Not working
janosek
Hello,
I have an RT-AC66U and I am running 378.52_2
I was reading that Private Internet Access allows having no cipher. Since I am using openvpn for netflix and not security, I don't care if I have encryption enabled. However, when I attempt to turn it off, I get the following in my log and the VPN does not work
Apr 16 18:37:57 rc_service: httpd 366:notify_rc stop_vpnclient1
Apr 16 18:38:07 rc_service: httpd 366:notify_rc start_vpnclient1
Apr 16 18:38:07 kernel: tun: Universal TUN/TAP device driver, 1.6
Apr 16 18:38:08 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Apr 16 18:38:08 openvpn[954]: OpenVPN 2.3.6 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Apr  5 2015
Apr 16 18:38:08 openvpn[954]: library versions: OpenSSL 1.0.0r 19 Mar 2015, LZO 2.08
Apr 16 18:38:08 openvpn[954]: WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Apr 16 18:38:08 openvpn[954]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 16 18:38:08 openvpn[954]: ******* WARNING *******: null cipher specified, no encryption will be used
Apr 16 18:38:08 openvpn[954]: Socket Buffers: R=[118784->131072] S=[118784->131072]
Apr 16 18:38:08 openvpn[956]: UDPv4 link local: [undef]
Apr 16 18:38:08 openvpn[956]: UDPv4 link remote: [AF_INET]216.155.131.74:1194
Apr 16 18:38:08 openvpn[956]: TLS: Initial packet from [AF_INET]216.155.131.74:1194, sid=19ccf43c 250e70af
Apr 16 18:38:08 openvpn[956]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Apr 16 18:38:08 openvpn[956]: VERIFY OK: depth=1, C=US, ST=OH, L=Columbus, O=Private Internet Access, CN=Private Internet Access CA, emailAddress=secure@privateinternetaccess.com
Apr 16 18:38:08 openvpn[956]: VERIFY OK: depth=0, C=US, ST=CA, L=LosAngeles, O=Private Internet Access, OU=Private Internet Access, CN=Private Internet Access, name=Private Internet Access, emailAddress=secure@privateinternetaccess.com
Apr 16 18:38:09 openvpn[956]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1526', remote='link-mtu 1542'
Apr 16 18:38:09 openvpn[956]: WARNING: 'cipher' is used inconsistently, local='cipher [null-cipher]', remote='cipher BF-CBC'
Apr 16 18:38:09 openvpn[956]: WARNING: 'keysize' is used inconsistently, local='keysize 0', remote='keysize 128'
Apr 16 18:38:09 openvpn[956]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Apr 16 18:38:09 openvpn[956]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Apr 16 18:38:09 openvpn[956]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Apr 16 18:38:09 openvpn[956]: [Private Internet Access] Peer Connection Initiated with [AF_INET]216.155.131.74:1194
Apr 16 18:38:11 openvpn[956]: SENT CONTROL [Private Internet Access]: 'PUSH_REQUEST' (status=1)
Apr 16 18:38:11 openvpn[956]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 209.222.18.222,dhcp-option DNS 209.222.18.218,ping 10,comp-lzo no,route 10.168.1.1,topology net30,ifconfig 10.168.1.6 10.168.1.5'
Apr 16 18:38:11 openvpn[956]: OPTIONS IMPORT: timers and/or timeouts modified
Apr 16 18:38:11 openvpn[956]: OPTIONS IMPORT: LZO parms modified
Apr 16 18:38:11 openvpn[956]: OPTIONS IMPORT: --ifconfig/up options modified
Apr 16 18:38:11 openvpn[956]: OPTIONS IMPORT: route options modified
Apr 16 18:38:11 openvpn[956]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Apr 16 18:38:11 openvpn[956]: TUN/TAP device tun11 opened
Apr 16 18:38:11 openvpn[956]: TUN/TAP TX queue length set to 100
Apr 16 18:38:11 openvpn[956]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Apr 16 18:38:11 openvpn[956]: /usr/sbin/ip link set dev tun11 up mtu 1500
Apr 16 18:38:11 openvpn[956]: /usr/sbin/ip addr add dev tun11 local 10.168.1.6 peer 10.168.1.5
Apr 16 18:38:11 openvpn[956]: updown.sh tun11 1500 1526 10.168.1.6 10.168.1.5 init
Apr 16 18:38:11 rc_service: service 998:notify_rc updateresolv
Apr 16 18:38:11 dnsmasq[788]: read /etc/hosts - 5 addresses
Apr 16 18:38:11 dnsmasq[788]: read /etc/hosts.dnsmasq - 0 addresses
Apr 16 18:38:11 dnsmasq-dhcp[788]: read /etc/ethers - 1 addresses
Apr 16 18:38:11 dnsmasq[788]: using nameserver 209.222.18.222#53
Apr 16 18:38:11 dnsmasq[788]: using nameserver 209.222.18.218#53
Apr 16 18:38:14 openvpn[956]: /usr/sbin/ip route add 216.155.131.74/32 via 24.52.233.65
Apr 16 18:38:14 openvpn[956]: /usr/sbin/ip route add 0.0.0.0/1 via 10.168.1.5
Apr 16 18:38:14 openvpn[956]: /usr/sbin/ip route add 128.0.0.0/1 via 10.168.1.5
Apr 16 18:38:14 openvpn[956]: /usr/sbin/ip route add 10.168.1.1/32 via 10.168.1.5
Apr 16 18:38:14 openvpn[956]: Initialization Sequence Completed
After this, the VPN does not work. If I go back to default encryption, it works fine.
PIA ties the encryption method to specific ports. For no encryption try using port 1195
yep, UDP port 1195, none for cipher, and "auth none" without quotation marks in the custom configuration.
Hello,
I was reading that Private Internet Access allows having no cipher. Since I am using openvpn for netflix and not security, I don't care if I have encryption enabled. However, when I attempt to turn it off, I get the following in my log and the VPN does not work ...
I don't know if this is a problem, but does not the encryption have to match the servers?
Also be aware of this thread about using VPN to a public server.
www.snbforums.com/threads/router-web-accessibility-from-wan-internet-when-an-openvpn-client-is-running.23743/
Thank you Cosmoxl and john9527! "auth none" (and earlier port 1195) was what I was missing!
Sorry to bump an old thread but this configuration no longer works for me, did it stop working for you using private internet access.com ?
Looking for anything to get it working again please.
