Skynet [SOLVED] Stil Skynet after formatting?
Stardust
Hey all.
I have tried formatting a USB drive several times, still Skynet appears as precent and needed upgrading. But it is not there because of formatting. What shall I do to make sure, that the drive also appears empty after using the "fd" command?
I can't find any suggestion.
Regards
ColinTaylor
Part of the Furniture
visortgw
IIRC Skynet installs in the jffs partition and not on a USB drive.
You're correct. Typically, ALL of the add-on scripts reside in /jffs/scripts.
