[Solved] Unable to load dynamic library '/opt/lib/php/gd.so
amplatfus
After entware-ng update (src/gz packages pkg.entware.net/binaries/armv7) to entware (src/gz packages bin.entware.net/armv7sf-k2.6) using opkg update; opkg upgrade 2 times I am facing below PHP error:
PHP Warning:  PHP Startup: Unable to load dynamic library '/opt/lib/php/gd.so' - libpng12.so.0: cannot open shared object file: No such file or directory in Unknown on line 0
Could you please give me some hint to fix it?
Thank you!
Thank you!
I solve it in the meantime #happy :)
Below are the steps in my case that worked.
1. I list packages installed on my Entware:
user@router:/tmp/mnt/# opkg list-installed
php5 - 5.6.26-1
php5-cgi - 5.6.26-1
php5-cli - 5.6.26-1
php5-fastcgi - 5.6.26-1
php5-mod-curl - 5.6.26-1
php5-mod-gd - 5.6.26-1
php5-mod-hash - 5.6.26-1
php5-mod-json - 5.6.26-1
php5-mod-mbstring - 5.6.26-1
php5-mod-mcrypt - 5.6.26-1
php5-mod-mysql - 5.6.26-1
php5-mod-mysqli - 5.6.26-1
php5-mod-openssl - 5.6.26-1
php5-mod-pdo - 5.6.26-1
php5-mod-pdo-mysql - 5.6.26-1
php5-mod-pdo-pgsql - 5.6.26-1
php5-mod-pdo-sqlite - 5.6.26-1
php5-mod-session - 5.6.26-1
php5-mod-simplexml - 5.6.26-1
php5-mod-xml - 5.6.26-1
php5-mod-zip - 5.6.26-1
php7 - 7.2.9-1
2. Then I uninstalled php5-mod-gd and installed php7-mod-gd.
user@router:/tmp/mnt/# opkg remove php5-mod-gd
Removing package php5-mod-gd from root...
user@router:/tmp/mnt/# opkg install php7-mod-gd
Installing php7-mod-gd (7.2.9-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/php7-mod-gd_7.2.9-1_armv7-2.6.ipk
Configuring php7-mod-gd.
And the error gone away.
Hope this helps!
