420kilobytes
EDIT: I solved my own problem. It turned out to be a setting on one of my many RT N16 repeaters that was messing it up. All devices on my network are using Merlin Asuswrt w/ repeater.
I have installed a RT-AC66U with latest Merlin beta to replace a RT-N16 running TomatoUSB.
Since making the AC66U I have noticed things that depend on multicast forwarding (such as 0conf/Bonjour) aren't working. I can't see iTunes shared libraries across my network, and OS X Printer sharing doesn't work, for instance.
I've had some of my devices running behind wireless routers set up in client mode on their own subnet, with a static IP on the main wireless (which is the AC66U's wireless now) but that doesn't seem to be working anymore.
I made sure I have wireless multicast forwarding turned on for both 2.4ghz and 5ghz.
Has anyone else run into similar issues, and if so, have you found any fixes/workarounds?
