Spammed by 384.14
carpov alexandru
Hello, i installed 384.14 on my ac68u and since then, i get the following messages, by the hundreds:
Dec 17 23:50:19 syslog: WLCEVENTD wlceventd_proc_event(449): eth1: Assoc 30:07:4D:28: d0:4E, status: 0, reason: d11 RC reserved (0)
Dec 17 23:50:19 syslog: WLCEVENTD wlceventd_proc_event(401): eth2: Disassoc 30:07:4D:28: d0:4E, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Dec 17 23:50:27 syslog: WLCEVENTD wlceventd_proc_event(386): eth1: Deauth_ind 30:07:4D:28: d0:4E, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Dec 17 23:50:30 syslog: WLCEVENTD wlceventd_proc_event(420): eth1: Auth 30:07:4D:28: d0:4E, status: 0, reason: d11 RC reserved (0)
Dec 17 23:50:30 syslog: WLCEVENTD wlceventd_proc_event(449): eth1: Assoc 30:07:4D:28: d0:4E, status: 0, reason: d11 RC reserved (0)
Dec 17 23:50:38 syslog: WLCEVENTD wlceventd_proc_event(386): eth1: Deauth_ind 30:07:4D:28: d0:4E, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
The above is highly trimed since there are hundreds of lines. As you can see, it happends every few seconds, for all my devices.
Also :
Dec 18 17:49:11 miniupnpd[887]: Unauthorized to remove PCP mapping internal port 17808, protocol TCP
Dec 18 17:49:11 miniupnpd[887]: Unauthorized to remove PCP mapping internal port 17808, protocol UDP
Dec 18 18:21:51 miniupnpd[887]: Unauthorized to remove PCP mapping internal port 17808, protocol TCP
Dec 18 18:21:51 miniupnpd[887]: Unauthorized to remove PCP mapping internal port 17808, protocol UDP
Is this normal? it was preatty quiet on the last build...
Any help would be apreciated.
EDIT: literally before all this started, i got the following error:
crond[243]: time disparity of 848758 minutes detected
but my router clock is correct. Not sure what's going on....
