PlanetaryEpitaph
Hi all,
I'm struggling to make my slightly goofy network setup function the way I want. Due to the layout of my house I found I needed 2 WiFi routers to provide enough coverage, and I'm having a hard time making a Plex media server available across both subnets. Here's the basic setup:
Cable modem -> Primary AC66U Router -> Secondary AC66U Router (connected via long Cat6 ethernet) -> Plex Desktop Server (connected via wireless to Secondary router)
What I'm looking for is the specific setting changes I need to make to allow full access to the Desktop from anywhere on the network.
More details:
Primary router has the following settings:
Wan IP: 192.168.1.69
LAN IP: 192.168.2.1, mask 255.255.255.0
DHCP enabled, serving out 192.168.2.x addresses
Secondary router has the following settings:
WAN IP: 192.168.2.224
LAN IP: 192.168.3.1
DHCP enabled also, serving out 192.168.3.x addresses
Plex server ends up at 192.168.3.114
(Side note: I had previously set the secondary router to use the DHCP of the primary router, which removed this subnetting problem, but seemed to cause very frustrating stability issues. As soon as I had the secondary router use its own DHCP instead, the network became stable. Therefore I'd like to keep the separate subnets and DHCP servers for now)
What I've done so far:
Disable the firewall on the secondary router.
Add a static route on the primary router with the following settings:
Network/host ip: 192.168.3.0
Netmask: 255.255.255.0
Gateway: 192.168.2.224
Metric: 1
Interface: LAN
At this point, I can access the primary router from the Plex server, by opening a web browser and going to 192.168.2.1.
However, if I'm on the primary router subnet, I can't access anything on the 192.168.3.x subnet.
Any suggestions please? Thanks in advance!
More details:
LAN IP: 192.168.3.1
Metric: 1
Interface: LAN
