EventPhotoMan
I have a RT-AX86U router, firmware 388.1, without wireless connections, just as a DHCP server and switch.
My cable modem is connected to my RT-AX86U, via the 2.5 Gbe port.
This router was connected to the rest of my home network using the 1 Gbps ports
I was getting 1.2 Gbps (on a 1.5 Gbps plan) vis spdMerlin tests.
then i changed things.
I connected the cable model to the normal WAN port, (1.0 Gbps) amd connected the rest of my home network you the 2.5 Gbps port.
I am geting appoximately 960 Mbps sped.
now i wanted to switch things back
i moved the ethernet cable from the cable modem back to the 2.5 port on the RT-AX86u.
and the rest of the network is connected to the 1.0 Gbps LAN ports.
Using the spdMerlin, I still only getting 950 Mbps speeds?
What setting could I have missed, as the speed is stll around 950 Mbps? I should be about 1.2 Gbps, like before.
