Splitting WLAN from LAN
datan
Hi all,
I would like to create a different subnet for my WLAN (from the physical ports). I tried to tinker with the dnsmasq.conf but it doesn't quite work. I think the LAN section is conflicting with the WLAN section. How can I split the WLAN from the LAN? Or should I have individual entries for each of the LAN ports?
See attached files, thanks!
thanks!
pid-file=/var/run/dnsmasq.pid
user=nobody
bind-dynamic
interface=br0
interface=pptp*
no-dhcp-interface=pptp*
no-resolv
servers-file=/tmp/resolv.dnsmasq
no-poll
no-negcache
cache-size=1500
min-port=4096
bogus-priv
domain-needed
dhcp-range=lan,192.168.2.2,192.168.2.254,255.255.255.0,86400s
dhcp-option=lan,3,192.168.2.1
dhcp-option=lan,6,208.67.222.222,208.67.220.220
dhcp-option=lan,252,"\n"
dhcp-authoritative
dhcp-name-match=set:wpad-ignore,wpad
dhcp-ignore-names=tag:wpad-ignore
dhcp-script=/sbin/dhcpc_lease
script-arp
interface=eth5
dhcp-range=eth5,192.168.10.100,192.168.10.120,255.255.255.0,86400s
dhcp-option=eth5,3,192.168.10.1
  • dns.txt
Not sure if that's possible w/ Merlin (at least using the GUI, maybe from the CLI). The problem is NOT DNSMasq per se. It's the fact that the wired and wireless network interfaces are *bridged* by default. To get the change you want, you need to *first* remove the wireless network interface from that bridge (usually br0) so it stands alone, then configure it separately w/ its own IP network, DHCP server, etc., using DNSMasq.
So I recommend digging around the forum further to see if someone has already accomplished that (probably has been done).
yup that's what I was thinking needs to be done (splitting WLAN or the physical ports from the bridge). Hoping someone has done it before.
