Hello!
I searched the forum, but nothing came up for 341U, so I thought I'd post asking:
Has anyone gotten a Netgeaur 341U LTE dongle to work with an AC68U router?
(For background, I'm running asuswrt-merlin 376.49_4 )
Here's what I've attempting so far without success:
-Tried out-of-the box, just plugging in hoping that the usb_wwan kernel module might work (nope).
-Tried compiling the GobiNet and GobiSerial (obtained from here: http://support.netgear.com/product/AirCard+341U+$28Sprint$29 ) kernel modules, and still no luck.
More on my adventures with the Gobi* kernel modules:
After compiling, I copied them to the /jffs partition, and loaded them with insmod. After they were loaded, I plugged in the dongle, but it still attempted to register with the usb_wwan module. So I unloaded the usb_wwan module with modprobe -r, and finally the dongle did register with the GobiNet module and gave me a usb0 net interface, but was unable to aquire an ip from the modem dongle. (It incorrectly got something on 10.0.0.0 net, but the modem should have given it something on 192.168.3.0 (the modem was in a mode that has a built in nat)). Statically setting the address into something in the correct range didn't work either - no communication with the dongle.
I also tried it with the 341U in it's 'ip passthrough mode' (which exposes two net interfaces), but had the same issues with it correctly aquiring addresses.
On a side note, I know the modem dongle does work correctly - I sucessfully built the same Gobi* kernel modules for my laptop with is running Linux Mint 17, and everything works great there, I just cannot get it to work with the AC68U running asuswrt-merlin 376.49_4, with either the Gobi* kernel module drivers, or the built-in usb_wwan, in either of the modem's modes.
Has anyone one out there gotten this modem dongle to work with their router, or have ideas what else to try?
Cheers!
Cheers!
