SSH access from guest networks (merlin 386.1/AX6000)
SwiftSpider
Dear fellow tweakers,
I've been using for years now merlin + yazfi, have some knowledge in sysadmin, however not as advanced in network configuration.
I as well have the main ssid routed to VPN ( through ip rules in VPN client config )
I have setup different guest networks with yazfi, routing through different VPN clients. This works well.
I can access intranet + ssh while connected through the main SSID( range 192.168.100.0/24 ), but I'm unable to do so while connected to the guest networks (192.168.90.0/24). Connection refused. (even if intranet access is enabled in guest settings). I did set policy rules to NOT STRICT in VPN config
I checked in iptables -L, could not check any restriction for that
What I would like to achieve, is to be able to restart router VPN clients through command line through ssh (which works well when I am connected to the main SSID) but also when I am connected on guest wifis
in advance, thanks a lot for your inputs!
