jauling
Just came from shibby-tomato, so apologies if this is a dumb question.
I did a quick search on port forwarding in this forum, but didn't find anything that specifically addresses my issue.
Running the just released 380.69 firmware on my N66U, and I would like to enable ssh on it using standard port 22 inside my LAN, but run it on a non-standard port on the WAN side. The UI doesn't support this but I thought maybe just enabling a port forward would do the trick, but it's not working as I thought it would.
The iptables rule looks proper to me, its the last DNAT rule in the VSERVER chain. Am I doing something wrong? FWIW, the other port forward rules below do work.
admin@crappy:/tmp/home/root# iptables -L -t nat -n
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
VSERVER all -- 0.0.0.0/0 MY-WAN-IP
Chain POSTROUTING (policy ACCEPT)
PUPNP all -- 0.0.0.0/0 0.0.0.0/0
MASQUERADE all -- !MY-WAN-IP 0.0.0.0/0
MASQUERADE all -- MY-LAN-NET/24 MY-LAN-NET/24
Chain OUTPUT (policy ACCEPT)
Chain DNSFILTER (0 references)
Chain LOCALSRV (0 references)
Chain PCREDIRECT (0 references)
Chain PUPNP (1 references)
Chain VSERVER (1 references)
DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:443 to:MY-NAS:443
DNAT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:1194 to:MY-OPENVPN:1194
DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:5903 to:PC1:5900
DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:5902 to:PC2:5900
DNAT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:2222 to:MY-ROUTER:22
VUPNP all -- 0.0.0.0/0 0.0.0.0/0
Chain VUPNP (1 references)
