SSH shortcut to switch LEDs on/off
Ro berto
Hello,
Is it possible to create a shortcut to turn on/off the router's LEDs?
Something similar to what @thelonelycoder did with Diversion and the iOS shortcut. (iOS Shortcut for Diversion).
On a similar note, is it possible to create another SSH shortcut for @Jack Yaz spdMerlin to enable/disable the automatic speed tests?
I found this:
#leds off
nvram set led_disable=1
service restart_leds
#leds on
nvram set led_disable=0
the problem is that is two lines, and on the android app there's only space for one line :(
edit: you can run several commands in a single line using the semicolon :cool:
problem solved :)
now onto the command for toggle on/off the automatic speed tests
anyone has an idea?
having issues with function AutomaticMode()
anyone has an idea?
Thanks @Jack Yaz again for creating such an awesome script and for helping me by adding this option in spdMerlin.
Here is my list of shortcuts (attached image), with their respective commands lines. I'm using the "SSH Button" app for Android:
LEDs on
nvram set led_disable=0;service restart_leds
LEDs off
nvram set led_disable=1;service restart_leds
Diversion on/off
diversion sh-a
spdMerlin on/off
spdmerlin automatic
Reboot Printer (sometimes printer is not detected so I reboot the usb2network service)
service restart_u2ec
Reboot Router
service reboot
any suggestions are more than welcomed
