SSH with Keys
Donga120
Hi guys,
I'm trying to setup SSH via Mac/Terminal.
I've followed this guide: http://tomatousb.org/forum/t-619135/guide-using-ssh-on-tomato-without-passwords-win-mac
But when I try to connect via terminal it just says:
ssh: connect to host 192.168.1.1 port 22: Operation timed out
Any suggestions? Never attempted SSH into the router before so pulling my hair out with this.
Enable SSH - LAN Only
Allow SSH Port Forwarding - No
SSH Port - 22
* Using a different port than the default port 22 is recommended to avoid port scan attacks.
Allow Password Login - No
Enable SSH Brute Force Protection - Yes
Is your routers ip 192.168.1.1?
Not sure then.
I would fire up Wireshark on my Mac and sniff what, if anything is being sent to the router when you try and connect.
Bit over my head that to be honest, but got these....?
Router is not responding on port 22 at all.
If the port was closed I’d expect it to say as much in a response. So maybe you have a firewall rule to drop the packets? You’d probably have had to create it though as I don’t think there are any in there as default.
As an aside; I’d get SSH working with password auth before switching to key based auth. Keep it simple and work up. Not that your issue is related to auth type at this point.
Is it possible its trying to connect via port 80 instead of 22, or not?
EDIT: No it's not! :D
That’ll be a web UI session you have open (incidentally you should switch to HTTPS Only instead of HTTP for security)
Do you have any other devices you could use eg an iPhone or a Windows computer?
(I use the Network Toolbox app as well as Termius on my iPhone for SSH, and Putty/WinSCP on Windows).
Sometimes the client device/program is the problem, but knowing that a different device can connect is very helpful in that you then know for certain at which end the problem lies.
And do take JDB’s advice: start with username and password and then work your way up to using PKI in addition.
Simple sanity checks:
  1. Have you pressed Apply at the bottom of the page after enabling SSH?
  2. Do you have any access restrictions defined at the bottom of that page?
Done. Thanks.
Yes I do, will try them. Although I've progressed, not sure wether its backwards or forwards but I started from scratch and now get:
Permission denied (publickey).
1. Yes.
2. Not that I can see. You mean at the bottom of Administration > System? If so, no restrictions is checked.
Does it work if you set Allow Password Login - Yes
Test with Enable SSH Brute Force Protection - No
If that doesn't work than reboot the router.
And you are absolutely certain you have entered your username and password correctly in the Terminal on the Mac?
The credentials will be the same as the web UI just for clarity.
100%. Upon looking closer, its says "MACUSER@192.168.1.1". If I'm correct, isn't it trying to log onto the router user my Mac name? Shouldn't this be set to say admin? Will give it a try...
Did you already generate the key and then move it to the Mac? If so, you'll need to put the key into the "Authorized Keys" box on the web interface.
