SSL Certificate present over WebUI login but not AiCloud
MTBer04
I've installed my domain-registered SSL cert on the router, and it works when I access the WebUI administrator login page (default https port 8443). However, when I access the AiCloud page, the certificate is missing, and I get a security warning.
Does AiCloud use a different server within the router that can't see the installed cert?
Solved my own problem- within the AiCloud page under 'Setting', there is a tab conveniently labeled 'Certificate', which allowed me to import my private key, cert, and intermediate cert. This seems to confirm my suspicion that the AiCloud server couldn't see the cert when installed via SSH, even though this method worked with the WAN-facing WebUI.
You can create your own self-signed certificate using something like OpenSSL, but it will still prompt a security warning in your web browser until you add an exception. If you're going to bother, do it right and obtain a 3rd-party SSL cert from a trusted authority (got mine from StartCom). To do this, you'll need to own your own domain.
