Static route dissapears
Mrs_Esterhouse
I have a static route in my Asus router set for my cable modem at: 192.168.100.1. It works great until I reboot by cable modem. The route will disappear from the Asus' routing table. The only way I know of to restore the static route is to reboot the router. Is there a command line I can run to reload the routing table so I don't have to reboot my router when my cable modem goes down? It had the same behavior with both my RT-AX86U Pro and RT-AC66U_B1 both running the latest Merlin firmware. Thanks!
